Vmax4
- Apr 18, 2003
- Orondo, WA
- 2010 FXNytro MTX 162 SE with a 270 hp MCX Turbo and assorted goodies!
I have a 2010 FXNytro MTX 162 with a 270 hp MCXPress Turbo. Looks like I have a broken driver. It is the one with the cog tooth that fits in between the track clip holes.
1st.... should I replace right away?
2nd... if replacing, what should I replace them with? Stock? After Market?
3rd... anything I should be examining or looking closely at when I pull that shaft?
4th... right time for a new track..... Camoplast Challenger Extreme 2.5"????
Thanks,
Steve
Thanks,
Steve
hugger70mtnmax
Aftermarket ones are much stronger. I have only used the wahl but I like them. If you are going to do a track that would be the time to do it. Track has to come out to change drivers.
bholmlate
VMAX
If you are boosted without question i would call Robbie at Avid and order new anti ratchet drivers for it and not worry about it anymore. There are others out there but time and time again i hear people on boost say that Avids are the only way to go. Change all of them and be done with it
While I had it apart I would look at everything in the chaincase and possibly replace the chain and gears if you have been running boost for awhile just for the peice of mind. Since everything in there was never designed to run that type of HP. I have read about people that have changed that stuff every season when running a lot of boost just for the added protection. I would also take a good look at the track bearing on both sides of the axle and replaced depending on how many miles you have on the sled. I have read it is a good idea to swap them out if you +3000 miles on the sled. Might as well look at everything while it is apart and replace things instead of putting old part back in and crossing your fingers.
If you have the money and are still running the stock track I would swap the track out at the same time. This is a no brianer if you still have the OEM track. Whole different sled with a good quailty track under it.
Vmax4
- Apr 18, 2003
- Orondo, WA
Yes, was planning on the track this summer, but might move that timeframe up a bit. Anyone have the phone number/webpage for the AVID DRIVERS?
Vmax4
- Apr 18, 2003
- Orondo, WA
I have one broken cog on my drivers as well have put a few hundred miles on it and have had no issues. But im not.boosted. if i was i believe i would defiantly be putting new avids on.
mtdream
Without question, best drivers are avid.... As bholmate says, call Robbie, he will take care of you....
http://www.avid-products.com/sled.htm
Vmax4
- Apr 18, 2003
- Orondo, WA
I ordered the following tonight:
7 Tooth AVID Drivers
162" x 15" x 2.5" Camoplast Challenger Extreme
Probably a good all around set up. Ah, it's only money..........
bholmlate
get ready for a whole new expereince riding your nytro with that setup. Good luck.
robo cop
- Jan 1, 2012
worn drivers
put 800 miles on this year in excellent conditions why would mine look like that? its a new sled... track and everything else looks new?
will warrnty pay for replacements?
Vmax4
- Apr 18, 2003
- Orondo, WA
Here is what I think after concidering everything I know about mine and also everything I have heard from others. I actually think I got the hyfax hot, track clips started to melt the driver.......... That is what it really loosm like after considering everything. I have heard of this happening.
AVID drivers, new track, and ice age rails...... SLED IS EVEN BETTER and puts me in more control of the 270 HP I am wrestling!
I would give the warranty a try, mine was out of warranty, and I didn't want the junk stock drivers anyways, so I didn't even try. Having worked the warranty desk at a large Yamaha dealer....... I can tell you one thing, it will depend on the guy at the dealership and if he is willing to call yamaha and do all the leg work.
robo cop
- Jan 1, 2012
ill call them and see probably not worth me replacing them... cant see them causing a problem.... sad to see the season end
Vmax4
- Apr 18, 2003
- Orondo, WA
I might have run them asis, had I been running stock hp. But with the turbo, I was worried about "down the road" issues.
