YamahaRX1_83
Hey Guys, found a broken arm on my sled today (naturally as there is 5" of fresh stuff on the ground). It's the front arm on the skid. I found other posts saying Yamaha updated that arm and beefed it up. My question is was there a recall on this? It's not under warranty anymore obviously.
Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
Nope, I think your buying one but try groveling to your dealer, he might do a deal for you if you have a good relationship with them.
Ruggybuggy
- Sep 1, 2013
Weld it up and ride tomorrow if you can. Odds are dealer will not have in stock and I hate to waste good riding time.
YamahaRX1_83
I don't weld, nor do I know anyone around that does. Think I'm going to order up a new one today and possibly take the broken one to get it welded so I'll have a spare if it breaks again. I found one one for 186.00 online at another dealer and the dealer near me wanted almost $250. I can't believe how badly it was broken, I attached a pic.
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
how many miles on your sled?
YamahaRX1_83
I believe it's around 2900.
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
Welcome to the club.......
Broke mine twice (1 was the updated version). Found a stock take off one on Ebay for $70 and welded 3/16 plate gussets onto it, had no more problems.
crazy_dave
- Jan 31, 2014
- Upstate NY
- 07 Phazer FX
porkchop said:Welcome to the club.......
Can you please post up a pic or just describe where you welded the gussets.
equillibrium88
- Jan 18, 2010
- North Bay Ontario
- 2007 Phazer GT
Schmidt bros has a kit to replace that front arm as well if you cannot afford the whole kit which also comes with an updated pivot link. You can send them your front arm and they can repair it and reinforce it for you.
I have a stock non-updated arm, it hasn't broke yet but then again the center shock is way too stiff from the factory which could have aided to the breakage. Need's yearly inspection.
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
crazy_dave said:porkchop said:Welcome to the club.......
It was done on all 4 corners (both sides), bottom about 1/2 way from the pivot point to the edge of the arm.
I had the updated solid "W" bracket which doesn't fit in the '07 OEM slots to mount as it's wider.
Used a Bridgeport milling machine to remove some material from it.
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
