Been fighting an over heat issue on my brothers boosted Viper. I believe it could have been over boosting from day one and in it finally took its toll. You can see the damage on the head and pistons.
Above you can see where the head gasket failed
Here are a few more images of pulling the motor and pulling the motor apart. We are going to crank up the boost to 8 to 12 lbs like my other Viper, with bigger injectors, PCV as well as a thick head gasket.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
You have been busy guy! I'm sure you were happy to finally find the problem. So was this a stock MPI kit with eabc ?
My snowmobile shop always has fun projects going. Me and Steph still went and rode one last time last weekend too
Anyway, yes it had a EABC on it but didnt when we originally purchased it. Had to convert it over and I think maybe it was pushed at sea level before it could be dialed back.
yamahaguy
Ride SAFE
- Apr 20, 2014
Do you have the EABC with the dot sticker that indicates that has the correct software?
Some of those were flashed with the wrong software causing overboost. hopefully you don't have one of those . Look for the dot on the black plastic module which will indicate MPI has checked it for the correct software flash. You probably had gauges on that one anyways im guessing.
Yes we were aware and had the correct EABC but as I mentioned I think it was roached before we put the EABC kit on it.
glad to see you found the problem. odds are with all the good stuff you are doing to it, it will keep him happy and suprise a few others guys.
Oh ya she will rip now.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Tom and all you guys amaze me...... good job!
It’s just a motor. Lol and there sure is a lot of crap to move to get it out
Good work guys and thanks for sharing.
Glad I have knock protection!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Wow hard to believe the bearings look so good!
That’s one tough motor 4 sure.
I really like how your doing all your own repair work, commendable.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Forget the shim, put some low compression pistons in since you are replacing them anyways. It must have been turned up past 8psi to do damage like that, or someone ran with shitty fuel and held it to the bar for a long time.
Thank you!!
Brother already had the time and money into machining and wanted to keep the cost low, so this is the route we take. If it was me I would have tapped the throttle and launched it off a cliff..LOL
- 32K
