JAZZ04RX1
- Dec 28, 2003
- Illinois
- 2016 SR Viper LTX-LE
The C&A RZ's could make the steering a bit heavy so I am going to start with the 6in carbides.
Viper Joe how heavy is the steering with the 9in carbides?
ViperJoe
I went with 9's cause of the additional weight of the turbo on mine. End of last season I couldn't get 9's so i got a 6 and it was fine too and less steering effort. I'm a bigger guy and the 9 didn't bother me.
If I were you I would start with a 6 and go from there.
JAZZ04RX1
- Dec 28, 2003
- Illinois
Thanks I agree to start at 6 and go from there.
jakehayamaha
These skis keep the sled from darting with just a single carbide? Or should I go with a twin carbide?
jakehayamaha
The I've got close to 50000 miles and they are awesome. Pair them with slim Jim doolies.
I put on some Razors with 4.5" Shapers. Finally got it setup so there is no ski lift, they turn hard but they bite good in the corners which I wanted... but they dart like crazy, I hate it! So my next step is to get some Slim Jim Doolies and hope that they still have the bite in the corners, I know the Doolies will fix the darting.
Just wondering if anyone else has tried Razors with Doolies? 4" or 6"??
butches
- Jan 4, 2008
- McHenry, IL
- 2015 X-TX-SE MPI Turbo 180
2017 L-TX-LE Sidewinder
Hurricane Tuned 225/240/270
Thunder Clutching
12,000 miles as of 2/8/2022
Guys, best is to fine tune the ski pressure and you will get the C&A RZ dialed in. Had them on my 2015 x-tx-se and now on 17 L-TX-LE Sidewinder and slight tweaks in ski pressure via the front shock on skid and you can make it a trail burner with easy steering and no darting
I am running Bergstrom 8" triples with their shims on back of ski saddle/mount
IMO all carbides will be fine just spend some time with small adjustments
JAZZ04RX1
- Dec 28, 2003
- Illinois
Butches thanks for the info. What made it better more or less ski pressure? I guess the other question is did you loosen the or tighten the front shock spring?Guys, best is to fine tune the ski pressure and you will get the C&A RZ dialed in. Had them on my 2015 x-tx-se and now on 17 L-TX-LE Sidewinder and slight tweaks in ski pressure via the front shock on skid and you can make it a trail burner with easy steering and no darting
butches
- Jan 4, 2008
- McHenry, IL
Thunder Clutching
JAZZ04RX1 less ski pressure helped the heavy or hard steering issue but then I would need to manipulate the throttle to steer better through turns so then I backed off the spring pressure 1 turn and it then made it perfect still easy steering and no need to decelerate to corner better, I never touched front springs just the front skid shock and my limiter strap out all the way
JAZZ04RX1
- Dec 28, 2003
- Illinois
Can I make the front skid shock adjustment by just turning the spring? Or is there a locking nut like the front ski shock? My limiter strap is in the stock setting will I need to adjust that? Sorry for the newbie question but heading North tonight and wanted make sure what I need to do in the morning before we head out.JAZZ04RX1 less ski pressure helped the heavy or hard steering issue but then I would need to manipulate the throttle to steer better through turns so then I backed off the spring pressure 1 turn and it then made it perfect still easy steering and no need to decelerate to corner better, I never touched front springs just the front skid shock and my limiter strap out all the way
tony2times
- Nov 6, 2015
- Michigan
- 2015 SR VIper
Tried to install my C&A's this past weekend. No matter how hard I tried, I could not get the ski bolt through the spindle. Any tips for compressing the rubber saddle? How are you guys doing this?
butches
- Jan 4, 2008
- McHenry, IL
Thunder Clutching
There is a locking nut on so you will need a hammer and chisel, my ltxle strap was all the way out since new
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
Have the front of the sled in the air to get the bolt started (say, on the outside of the ski). Then grab a 2x4 board. Lower the sled with the board under inside portion of the ski - which is the opposite side that you started the bolt on. You might still need to stand on the ski to 'tweak' it a bit to have the holes line up. Then tap the bolt through with a hammer.Tried to install my C&A's this past weekend. No matter how hard I tried, I could not get the ski bolt through the spindle. Any tips for compressing the rubber saddle? How are you guys doing this?
