StinkyFingers
Hey folks, 2016 xtx - Just got done oil change (chaincase and engine) what a pita doing it on the ground. Have a very very small leak from bottom of case, but I'm going to leave it for now and watch my fluid level through the stupid "window".
Anyways, fired it up to test things out while on a stand and a couple noises stood out, as I dont think they were there before (at least not that I noticed). Sled only has 3100 kms/1900 miles on it.
1) primary noise when its disengaging, seems a little harsh. Louder in person vs on phone.
2) reverse noise when its rolling in reverse and I hit the brake. CLICK! again louder in person vs on phone.
What are your thoughts? Normal-ish? or STOP!! lol. I have the option to take it into the dealer tomorrow morning on my way out of town, but would rather not of course. Maybe it just needs a little rip to get the cobwebs out as this is the first time running since end of Feb.
Thanks!!
Thanks!!
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Clutch sounds the same as my 2016. I suspect the noise when hitting the brake in reverse is the chain pushing the tensioner against the adjuster bolt.
Yes sounds normal to me.
StinkyFingers
Thanks guys, don't really run it much with the track in the air. Previous sleds weren't as loud so thought I'd double check.
sailor joe
- Apr 4, 2019
- ma
- 2016 RS VENTURE TF
2020 SIDEWINDER GT
the reverse noise could be the clips on the track...normal enough. I'd be more concerned with the oil leaking..good idea to keep an eye on it. Sure it's not the engine oil leaking? That seal is subject to leaking. Sled sounds great!! Joe
StinkyFingers
Funny my initial thought was the clips as they were pretty rusty. I'll take her for a spin later today in the snow. I'm sure it will be fine and I'm just being more anal than usual.
As for the oil definitely chain case. It's about 3 ot 4 drops a day. Had it sitting for a week apart with only the case filled .. Hadn't filled the oil tank at the time.
trail traveler
- Dec 3, 2014
- Everett, WA
- 2015 sr viper s-tx-dx
2014 Venture MP
2016 RS Venture
2017 sr viper x-tx
3- 1990's era Arctic Cat prowlers
Was the color of your chaincase seal the original black seal? If so you may want to get the superseded thicker seal (red) for a replacement. My leak was noticeable on my trailer floor and I was concerned that once the chaincase oil warmed up from riding that it would leak even faster. After replacement, I haven't had a leak since. Here's the thread.
https://ty4stroke.com/threads/chaincase-o-ring.154095/
StinkyFingers
Hey there. I didn't take the cover right off, just split it a bit to drain the oil. Not sure which gasket I have but guessing the old one if the outdated one came on the 16s. I don't think the case has ever been apart, just drained and refilled.
1999 Fatboy
- Nov 15, 2019
- 2018 Yamaha SR Viper LTX-DX
Sounds like my 2018 Viper, infamous Yamaha clutch noise.
