sledfvr
I just bought this sled 03 rx1 beginning of the season. The first ride it ran great and didn't miss a beat. Second ride rode good half day and started popping and acting lean. I have 145 main jets in and 360 in the pitot. I didn't have billet t's so I orderd some and put them in. I checked for boost leaks and found none. I noticed the tps sensor (I think this is it on the pto side of carbs) had a torn boot so I sealed it and put it back together. It will boost up to about 8 lbs and then pop and sputter. It sounds like it pops a little even at idle. I tried blocking off the pitot jet and it doesn't seem to make much difference. I am getting tired of this. Please help
rx1 turbo 1 ton
- Dec 27, 2007
try your charge tube maybe blown apart i have a stage 3+ bender and that happend to me
sledfvr
found that and had it welded already and still runs like crap
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Do you have a WideBand O2 sensor AFR meter onboard? I strongly suggest you get one on a stage 3 turbo kit. If you already have one, what does it tell you?
rx1 turbo 1 ton
- Dec 27, 2007
try billet caps for your carbs take carbs off and seal everything make sure your vacum hoses are going to intercooler and charge tube they are not backwards call justin at full power he is great
twisted boost
- Jan 14, 2007
- Wenatchee,Wa
- www.sangstermotors.com
rx1 turbo 1 ton said:try billet caps for your carbs take carbs off and seal everything make sure your vacum hoses are going to intercooler and charge tube they are not backwards call justin at full power he is great
Justin is a great guy and super helpful give him a call...
sledfvr
I have carb caps and o2 kit on order. I called justin at full power and he told me that was a setup that outlaw motorsports came up with and he knows little about it. I did find a few boost leaks here and there on the sled and fixed them. All I can figure is that maybe instead of finding leaks the previous owner just jetted it richer and richer to compensate. thanks for the help guys. this site is awesome!!!
sledfvr
down to 130's and she runs awesome thank you spray25 and everyone else for the help. amazing how poor they run when they're too rich.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
sledfvr - great to hear she's up and running
