fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Hey guys. Sleds apart for its yearly maintenance and a track swap. Looking at turbo it seemed to have a ton more carbon build up than before. It’s maxspool 17 tune cai and 2.5sq. Any suggestions or just let it go? I would attach file but can’t get photo small enough
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Let it go
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
What brand of oil do you use?Hey guys. Sleds apart for its yearly maintenance and a track swap. Looking at turbo it seemed to have a ton more carbon build up than before. It’s maxspool 17 tune cai and 2.5sq. Any suggestions or just let it go? I would attach file but can’t get photo small enough
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I use this APP for resizing pics. Works great.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Klotz estorlin, yamalube first 2 years then tried amsoil but switched since they don’t make a 0-30 only a 0-40What brand of oil do you use?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
First thing I'd do is throw that crap in the oil recycling barrel! Racing lubes don't contain much or any TBN or detergents. You don't want racing oil for trail use that in these snowmobile turbo engines. Plus Klotz is bottom of the barrel when it come to wear protection.
Quaker State 5-30 has the best wear protection and rated #1 right now according to the 540 Rat blog. Using 5-30 Mobile One or any good synthetic would be better than Klotz Estorlin Racing Oil.
Read this and form your own opinion, but I don't think you'll be using Klotz Racing Oil after your done reading, just saying. 5-30 Klotz Estorlin Racing oil is rated 234th out of 261 oils tested. Pretty much bottom of the barrel for wear protection. https://540ratblog.wordpress.com
STAIN
- Feb 29, 2004
- Vermont
- Vermont
The carbon build up is likely due to your choice of oils.
Without getting too deep into an oil discussion, you really can't go wrong with Mobil 1. I run 0-30 and have run 0-20 in the past with good results.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Where does it say he is using racing oil?
He never said that. He said he was using Klotz estorlin.
KnappAttack
- Feb 19, 2004
- Welch MN
Do a search on it. Thats what the label says. Plus the fact its extremely poor performing and bottom of the barrel wear rating according to Rats 540 Blog.
KLOTZ™ PURE ESTORLIN® RACING SYNTHETIC ENGINE LUBRICANT
Designed for racing and performance applications to increase torque and horsepower Meets and exceeds warranty requirements for compliance and protection Improves acceleration and throttle response Contains extra zinc and phosphorus to protect critical engine parts Extends cam roller bearing...
klotzlube.com
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
So your saying the klotz oil that’s rated in this blog is the same oil the guy posted is using? That’s my only question.Do a search on it. Thats what the label says. Plus the fact its extremely poor performing and bottom of the barrel wear rating according to Rats 540 Blog.
Designed for racing and performance applications to increase torque and horsepower Meets and exceeds warranty requirements for compliance and protection Improves acceleration and throttle response Contains extra zinc and phosphorus to protect critical engine parts Extends cam roller bearing...klotzlube.com
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
SNOWX4® PURE ESTORLIN® ENGINE LUBRICANT
Meets and exceeds API and JASO requirements for complete warranty compliance for all leading snowmobile manufacturers, including Yamaha®, Ski-Doo®, Arctic Cat®, and Polaris® PURE ESTORLIN® technology extracts peak horsepower Identifiable Klotz red color and racy scent Increases torque for...
klotzlube.com
This oil was rated in the blog? I want to see the results on THIS oil.
KnappAttack
- Feb 19, 2004
- Welch MN
If it's Klotz Estorlin 5-30 than that's the oil that rated 234th. in Rats Blog.
KnappAttack
- Feb 19, 2004
- Welch MN
Meets and exceeds API and JASO requirements for complete warranty compliance for all leading snowmobile manufacturers, including Yamaha®, Ski-Doo®, Arctic Cat®, and Polaris® PURE ESTORLIN® technology extracts peak horsepower Identifiable Klotz red color and racy scent Increases torque for...klotzlube.com
Here it is. 234th on the list. Rat calls this "moderate protection" for wear protection.
Here is the Quaker State 5-30, #1 on the Rat Blog list for wear protection.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Not sure that’s the snow 4x they make it for auto use also and it’s a totally different blend. But I do get what you are saying.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
