ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Have not been on TY4s for several days,cause I've been busy....(not in the good way)
-getting towed for many miles in deep snow
-loading 600 lb sled onto truck
-ruining a trip for my buddy and I (still have to pay for rooms and trip ect)
-got a whopping 1o mile ride total
-wrenching this sled into a zillion pieces when i got home
Funny thing is, when it happened I was 99% sure what it was because of this site. Gotta love this site and the community here as we all try to help each other with the CAT DNA(as Knapp says).....and a thread that I followed closely last fall was in my mind when i heard a slapping noise preceded by a vibration around 60mph.
Yep....the dreaded Tensioner roller wheel issue caught up with me. Approx 2400 miles and when I looked at it this fall the screws into the wheel looked fine. Grrrr....
Right off the top, I will say.....to remove your chain case entirely(meaning front and rear) down to bare tunnel is much more work then I thought(Thanks Mike for all your support brother). You name it, and it likely needs to be removed! grrrr...
Way too much to type, so I'll just slap up a bunch of pics and try to get them into succession to see what's involved.
Lots to do the next few days, and Ill fill in more posts here as I get things back together.....Ofcourse it was a DOO 2s that towed me out(My bud) and isnt that always the way? lol.
Dan
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
more....
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Yep keep tearing parts off to get that rear case out...lol
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Last batch of pics....Yes you need to remove alot to get that case out.
These are the parts I ordered...rear case all comes as assembly with bearing ect all included, front case comes with elec wiring ect...and tensioner comes with roller wheel already installed, you can bet I will be tack welding my roller wheel screws!
number1kyster
How can this be avoided? Remove the bolt, apply loc-tite, and re-tighten?
SH!T that sucks man sorry to hear. Now you make me want to take mine apart to look at it.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Its usually the back one you cant see until you remove the adjuster then the screw falls out.
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
For the record the new adjuster i got had green loctite on both screws.
klr650r
- Jan 26, 2018
- New Brunswick
- 2018 Yamaha Sidewinder R-TX LE 50th
I narrowly missed the same thing...When I did my service at the start of the season...the screw holding the wheel fell into the bottom of my case as I pulled the cover. Ticking time bomb for sure.
klr650r
- Jan 26, 2018
- New Brunswick
Did it crack your chaincase ??
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Yes the roller fell down, and sat right here and cracked case, Chain and gears look fine as I only skipped tooth one time when I tried to take off.
Backside
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I will have mine tack welded like a few others have done. Im not gonna trust the loctite as this is a ton of work to pull this sled apart..grrrHow can this be avoided? Remove the bolt, apply loc-tite, and re-tighten?
Dan
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Guess you never got to try the dalton white for many miles lol.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
My rear screw remained in place as seen in pics, it was tight against rear wall of case and actually kept tension on chain abit as chain rode against the screw itself. The front screw was out completely and found at bottom of case all mashed up as seen in pics. Roller just dropped and sat there as shown, wedging against case which cracked rear case.
Man what a pain in #*$&@....I was half way into the job before I realized how much had to come out to get case out, I likely would have let the dealer do this one if I had known!
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
LOL, 10 miles only.....I actually thought it was a blown belt but it was worse when I stopped.Guess you never got to try the dalton white for many miles lol.
Right in the middle of Trout lake(NB).
Dan
