black07fx
so i have a 07 fx and i broke the center link that couples the shocks last night . I found an 08 update kit for it is that the best way to fix this so it doesn't happen again ? I did see all the info about it in the stickeys at the top but all of that seemed to be from a couple years ago ! thanks
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
Here's my, HOPEFULLY, last fix. Not the prettiest job, but i'm confident i'll hold up.
http://www.ty4stroke.com/threads/broken-pivot-arm-fix.133678/
If you don't want to fix, buy the updated arm for the 14XTX. I through a pic of the added gussets Yami did. I bought the updated arm and broke quickly.
Hope this helps ya out.
Curious, what and where are all your suspension settings at? Particularily the limiter strap and front shock??
black07fx
alrighty thanks ! just had my shocks revalved by schmidt bros before the season but the suspension settings i am running so far limiter strap #2 front shock spring about 3/4 of the way to the top of the threads back shock compression rite in the middle and the torsion spring on med .
black07fx
that is with the softer center shock spring from schmidt
