apex4
hi,
Guys have you ever seen the chain case leak only after fixing the reverse ( adjusting srews), i had a lot of problem with this but finally fixed it, after that the case leaked for awile and then stopped??? yes there is the the right amount of fiuld in the case, did not leak all summer and i started it and ran it no leak?? Would the changing of reverse pressurize the case and make it leak( out the bottom) I do not want to pull of cover if not needed as we know the linkage would have to redone!
thanks
thanks
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Did you change the fluid and miss some when you cleaned up.
