Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
Was also going to change my chain case oil but the Bottom torx screw has the insides of the torx striped out.
I pointed this out to the salesman when I picked it up that the screw there looked bad as I could see the paint off an metal showing .
sure enough there was a problem as this was the first one I tried.
What do you think is the best way to get this out?
I was thinking about drilling out the rivets that holds the guard cover and trying it with vice grips?
It's not time to change chain case oil as I only have 900 km but was going to do the complete service as I just changed the motor oil . But Might have to wait now tell end is season.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
I would try both american and metric allen wrenches in the torx head. You might get one to fit well enough you can remove it.
If that does not work i have also had success using easyouts
You will need to grind the easyout down to fit tight in the stripped torx head.
It takes some time but usually works
rednav
- Oct 16, 2015
- Aylmer, Ontario
- 2015 STX-DX
consider using a mig welder to build it up and weld a nut on it.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Cut a slot in it and try to use a screw driver with a wrench or impact driver.. Replace all with 6x1.0mm bolts.
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX
2018 High Country 9000
2001 SRX 700
When I encounter that kind of problem, I try to enter the tightest torx or hallen I can, and at the same time work with vise-grip on the outside helping you to loosen that fastener. Most of the time it work.
Take it to the dealer and have them change the chain case oil. It was them that did that when it was leaking before you got it and they tighten it up to stop it from leaking.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Try a screw extractor spiral flute
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
Got it done now thanks for all the suggestions .
jeffgilbert
- Dec 17, 2007
- Newfoundland
- 2019 Sidewinder BTX LE
I had to use a heat gun to loosen the loc tight and the torx wrench the came in the tool kit when I ran into the same issue
