razor_220
- Dec 21, 2012
- Saskatchewan
- Yamaha Nytro X-TX(sold)
Yamaha SRViper X-TX(sold)
Yamaha sidewinder B-TX
Hey guys!! Hopefully everyone is having a good February!
Went and checked chain tension on sidewinder today and i could screw the bolt all the way in.
Removed cover everything is still together, but that top gear has play in it.
Is it safe to say that top gear bushing is gone!?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
If it wobbles is gone! It should be snug and not move on the shaft.
Tack Weld the tensioner screws while you are in there!!!!!!!
razor_220
- Dec 21, 2012
- Saskatchewan
Thanks Knapp!! Tack welded tensioner last year.
Notice the bottom 2 big gears wobble a bit also! thats probably not good either?
That's normal.Thanks Knapp!! Tack welded tensioner last year.
razor_220
- Dec 21, 2012
- Saskatchewan
Okay good!! Was just checking prices!! Haha!!That's normal.
Would the chain loosen that much from top gear failing? Or you thing chain is streched and needs to be replaced too?
A worn top bushing will cause the chain to loosen. Chain should be good for many miles, what's it reading?Okay good!! Was just checking prices!! Haha!!
razor_220
- Dec 21, 2012
- Saskatchewan
I have just over 7500km(4660miles) on my winder!A worn top bushing will cause the chain to loosen. Chain should be good for many miles, what's it reading?
Do you have adjustment left with the new bushing in?I have just over 7500km(4660miles) on my winder!
razor_220
- Dec 21, 2012
- Saskatchewan
Probably best to purchase the DMC top gear and super bushing!!
razor_220
- Dec 21, 2012
- Saskatchewan
I havent gotten a new bushing yet! But when i do install new bushing i check it then if i need new chainDo you have adjustment left with the new bushing in?
It will be a sign. Also look at the teeth on the top sprocket. Are you replacing the bushing or buying a new gear with the bushing?I havent gotten a new bushing yet! But when i do install new bushing i check it then if i need new chain
razor_220
- Dec 21, 2012
- Saskatchewan
Was looking at getting this!! Hopefully i'm okay to paste this!?It will be a sign. Also look at the teeth on the top sprocket. Are you replacing the bushing or buying a new gear with the bushing?
https://www.ebay.ca/itm/DMC-21-22-2...rentrq:b73761ce1770ac3ea4eeb03cffca4f9b|iid:1
That’s the DMC setup.He is a vendor here. Call him. Might be less than EBayWas looking at getting this!! Hopefully i'm okay to paste this!?
https://www.ebay.ca/itm/DMC-21-22-24-Tooth-Top-Gear-Super-Bushing-Sidewinder-Thundercat-1702-490/124381715131?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20160908105057&meid=fcfb42e61f09499995c150001bf0a125&pid=100675&rk=1&rkt=15&mehot=none&sd=124381715131&itm=124381715131&pmt=0&noa=1&pg=2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci:f6e3d9dd-7236-11eb-ae82-129e13dfe8ce|parentrq:b73761ce1770ac3ea4eeb03cffca4f9b|iid:1
razor_220
- Dec 21, 2012
- Saskatchewan
Yeah you bet! I sent him a message, just waiting for reply!!That’s the DMC setup.He is a vendor here. Call him. Might be less than EBay
razor_220
- Dec 21, 2012
- Saskatchewan
Hey Cannondale!? Where can I find DMC contact info?That’s the DMC setup.He is a vendor here. Call him. Might be less than EBay
- 13K
