DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
This is the best tool I have bought in a while. Got it from Matco tool guy. Makes getting those clips on and off so easy.
For others like me who realize they need to buy this tool after spending WAY too long fighting to get the clips off with screwdrivers, the Knipex Part # for this wrench is 4510170.
Amazon link:
https://www.amazon.com/gp/product/B003UHUCQM/ref=crt_ewc_title_gw_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
Is it possible to have a bushing pressed in to replace the top gear bush? Up here, Cat has the gear listed for $108!
twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE - TD Power Trail, CAI, 3" Super Quiet
2012 RS Vector
2006 Apex GT
- Middleville, MI
Yes...
Keith Furst
- Jan 17, 2015
- sr viper
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
I bought 3 of them from a local distributor and have installed one so far for a friend who will be trying it in a Sidewinder. They are a Bunting Bearing ToughMet 3 bushing #TMCB161808. Grainger & Zoro sell them. They will cost more than what a new gear/bushing does but I am being told that they will never wear out. They have 15% nickel in them.
They are not just a drop in replacement. The bore needs to be enlarged around 0.003" in order to get it to fit back on the shaft after it is pressed into the gear. I also don't know yet if the width needs to be trimmed. The stock bushing is 7/8" wide. These are 1" and will stick out one side a bit when pressed in flush on the other. I may contact the manufacturer and see if they are able to make them them the right size specs to be a direct replacement.
Keith Furst
- Jan 17, 2015
- sr viper
Since the gear needs to be bored out, I wonder if anyone has considered using a needle bearing and race? Both would require press fit to prevent spinning on shaft/bore.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
The bushing gets bored, not the gear. Also, the bushing only spins on the shaft when in reverse so I don't see how a needle bearing would help.
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
Thanks for the info, for now, I ordered a stock replacement gear. I'll keep the original and see what I can do with it.
My dealer told me the stockers have a teflon liner. If true, it wouldn't seem to be very robust. It was $102 CAD.
honda400ex2
Hi,
I had my 2014 Viper for one season now, has about 3600 miles on. After reading the 2 or 3 different threads, I am thinking of opening up the chain case and checking for wear. I am a little unsure about the gears that are prone to wear or fail. Could someone point out which numbers on the attached picture I should be looking at for wear?
Cant read yours. #20 is the gear the bushing wears on and #26 is the tensioner the bolts fall out of. These are from a RTX so your XTX will have a different gear.Hi,
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
In your pic #19 is the gear and 25 is the tensioner that cannondale27 is referring to.Hi,
Crap I must be getting old. Cant read that!Thanks FabioIn your pic #19 is the gear and 25 is the tensioner that cannondale27 is referring to.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Lol aren’t we all.. I just clicked on the pic and it expanded clearly for me..Crap I must be getting old. Cant read that!Thanks Fabio
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
Same here. I clicked the image and it was nice and clear.Lol aren’t we all.. I just clicked on the pic and it expanded clearly for me..
Yup with the readers on I can read it. So yes I am getting old!Same here. I clicked the image and it was nice and clear.
