Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I am interested if there are many people that have had chaincase issues due to an aging reverse chain - snapping, links breaking, etc.
I replaced the main chain in Summer '23 with 15,000 km and was wondering if i should upgrade the reverse chain as well this summer.
Sled now has shy of 17,000km and plan to run it into the low 20's.
MS
MS
raptordan
- Jul 5, 2004
- Barrie ont.
- 2025 SRX
I had to replace my reverse chain around 25000k
When in reverse it started skipping and made a terrible grinding sound obviously
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
For the sake of not breaking it, or worst it taking out the rest of the chain case I would do it next time your in the chaincase… You take care of your machine and your machine will take care of you is how I see it. I was told by a good source that if you run lower gear unit oil in your chaincase that they use on boats ( Mercury) you get no wear on any of parts or chains and when you change it there is no metal or metallic in the oil. I found that interesting but have not tried it yet…
Turboflash
- Mar 18, 2019
- Southern MN
In general, even brand new I think they're too loose. I wish there was some kind of a small tensioner or something. Seems like trouble waiting to happen.I am interested if there are many people that have had chaincase issues due to an aging reverse chain - snapping, links breaking, etc.
MS
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
I have often thought the same when it was apart. Its so loose it looks like it could skip a tooth spinning around in there at god knows what rpm.In general, even brand new I think they're too loose. I wish there was some kind of a small tensioner or something. Seems like trouble waiting to happen.
Too bad there isnt a way to take a link (or two) out. At a minimum a tensioner would not be too much to ask for.
MS
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
Mine started skipping as well around 25000kms so swapped it out. That chain is always spinning.
- 52K
