hognit09
- Mar 7, 2010
- beaver dam, wi.
- 2016 viper ltx le,2016 viper ltx dx
leaving for a trip next week, prolly gonna put on 500-600 miles,am i gonna have to pull muffler to readjust chaincase tension or should i be alright till i get home, sled is brand new. not really wanting to pull muffler outside on trip
olie72
I have a 2016 LTX LE. My chain got really loose at 260 miles. I had to do mine. So I would for sure say yes at some time if you are putting that many miles on a brand new sled, that you would have to tighten your chain.
hognit09
- Mar 7, 2010
- beaver dam, wi.
How much of a pain is it to get muffler off and back on?
trail traveler
- Dec 3, 2014
- Everett, WA
- 2015 sr viper s-tx-dx
2014 Venture MP
2016 RS Venture
2017 sr viper x-tx
3- 1990's era Arctic Cat prowlers
As I recall, the muffler itself wasn't that hard to reinstall. Your concern will be the gasket surviving upon removal. I purchased a copper gasket from Muffin Works for necessitating future removals. Also the springs require a bit of an effort. I used a cable tie that I looped under the spring end, pulled it into place, then simply cut it and threw it away. Cheap, easy tool.
hognit09
- Mar 7, 2010
- beaver dam, wi.
were is the spring, dont remember seeing a spring just the 3 nuts
swampcat
One spring, upper inside rear. Use a single edge razor and shave next to each metal pipe after you take bolts out, but before you pull the pipes apart.
Mine split first time and reused it 2 more times. Just check for leaks.
Vilas
- Sep 6, 2014
- Urbana, Illinois
- 2014 Viper xtx, Thunder products clutch kit
I got a copper gasket fro Ulmer which is reusable.Mine split first time and reused it 2 more times. Just check for leaks.
- Apr 14, 2003
- Hessel, Michigan
Copper gasket from Muffin Works....re-use it over and over and over. Best $25 bucks I spent for removing/installing the exhaust.
