Change the reduction gear shaft on the apex whitout removing the engine?
Apexmtx turbo
Age
46
Sweden
Sweden
Yamaha apex mtx turbo
Hi, is it possible to change the reduction gear shaft on the apex whitout removing the engine?
Thanks in advance!
Ok, is nr 7 the statorgasket?
I have everything else, including the gear reduction shaft and inner bearing
You can watch this vid. Its a time lapse of the removal, shaft change and installation of the motor
Here is a thread of my swap out that may help a little as well
