TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
I have a hairline crack and a dent on the left half of my bulk head.....does the motor need to be pulled to change it out?
bdm
I would bet that the answer is "no". You do NOT have to pull the engine in the RX, but I do not have an Apex.
PwdrNut
- Jan 16, 2005
- Salida, CO
- www.haboost.com
No you do not.
niko
Ok so I just got mine out and got it all done in about 4 hours. Its not a hard job at all. You need to remove the front plastics, bumper, battery, airbox, battery frame, a- arms.
Then the inner steering arms, once thats done then you need to remove the pop rivets on each side as well as the motor mount bolts.
Then the oil tank needs to be drained and remove the bottom oil line hose.
Once thats done remove bulkhead and your ready to replace.
BenderSRX
- Nov 29, 2006
- Constance Bay Ontario ( Ottawa )
- 2013 Yamaha Nytro RTX
I had to replace mine on my RX1, one thing to becareful on is punching out the rivets near the water pump. I had the misfortune of punching a rivet through the water pump.
niko
Hitting the water pump?? Where's that near the bulkhead?
bdm
x2 on the water pump cover caution. Dealer put a hole through mine removing a bulkhead rivet - left side very bottom.
then again, they were a clueless lot
BenderSRX
- Nov 29, 2006
It was not hard to do. I was tapping the last rivet out and on the first couple of taps it did not come out so a buddy that was helpping me told me tap it a lttle harder and the coolant started to flow.
niko
Had a close look its all good, I had used a 4" grinder to grind off the rivet heads then I tapped through the rest.
