jonnyz36
I Needed to change my hand warmers and got new grips too.
Just wandering what the easiest way to install the new grips is?
DelgatyXTX
Air compressor nozzle in one end of the bar helps to "inflate" the grip so you can slide it on. Also, this may be gross, but spit makes a nice lubricant that dries over a few hours. Worked on my GF's dirtbike grips.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
I used RSI gel wrap grips this last year with the stock elements. Very comfortable grips, just have to be careful removing old grips. Easy to install, just wrap them on and tape the ends.
jonnyz36
DelgatyXTX said:Air compressor nozzle in one end of the bar helps to "inflate" the grip so you can slide it on. Also, this may be gross, but spit makes a nice lubricant that dries over a few hours. Worked on my GF's dirtbike grips.
Thanks. That's what I heard from someone else as well.
