steveg_nh
I am getting ready to change the oil and plugs in my new to me 07 Attak. Dealer gave me NGK CR9E plugs. Just checked manual and it says they should be CR9EB. I read up on the differences and the "B" has the fatter typical tip at the top of the plug. The CR9E just has a thin threaded tip.
Before I get surprised and pull the plugs in there and realize I do in fact have the wrong ones (and then can't finish the job), can anyone help me understand what I should have? I would think using the thinner CR9E with the threaded top would not be correct if the wires are calling for the larger tip.
Winderallday!
Get the 9B's the 9E's are for RX-1's and will not fit the plug wire boot.
steveg_nh
You mean get the EB not just the E?
Winderallday!
Ya sorry, get what the manual states CR9EB.
Dealer gave you incorrect plugs if they only have the threaded cap.
steveg_nh
pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
Yes, "those things" are coils/plug boots.
steveg_nh
Awesome thanks
Winderallday!
This guy show below, along with a proper spark plug socket with rubber grommet, will be your best friend in removing/installing the plugs from the motor. You can work around most of the wiring and brackets etc, but I have found removing the overflow jug and setting it aside makes life easier on that side of the sled.
A rotating back and forth motion on the coil/plug boots while pulling upward is the best way to remove them, put some dielectric grease on the outside of them when re-installing to simplify next time. Cheers.
steveg_nh
Thanks. Much appreciated. I have the swivels, so that will help. Are you using that on the plug end, connected to the plug socket, or at the top of the extension near the ratchet head?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I find the best tool for the job is in the tool kit that came with the sled. it fits perfect.
Winderallday!
Generally I use a short extension in the spark plug socket, then the swivel, another short or long extension as needed, then a ratchet.
Also, takes a bit of horsing around to get the connectors off the plug boots/coils, need to find a way to release the retainer clip inside to allow them to be pulled off, not much extra wire to work with tucked away down there.
steveg_nh
You nailed it. And of course, I did have the CR9EB plugs. Thank goodness I checked. I would have been piseed if I didn't realize it till I got the old plugs out. My boots popped right off. Easy peazy. Previous owner or mechanic had dielectric grease on the boots. Easy as pie. And you're thoughts on the setup for the extensions and swivel were spot on. Socket>3" extension>swivel>6" extension. Pretty straightforward process actually.
I did realize I did not have the ability to use my small (1/4" drive) torque wrench though, and I really didn't want to risk over tightening. I did it by feel and got nervous on the first one so I backed it out just finger tight. I bought a 1/4" female to 3/8" male adapter so I could use my small inch pound torque wrench. My 3/8" torque wrench was too low in it's range to really be effective at 9-10 ft lbs. I didn't trust that either.
