SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
- '18 Sidewinder XTX-SE
After having my sled out last weekend I noticed I was only making 15.5 PSI of boost on a TD max spool 16 tune. I would like to run a quick leak test tonight when I get up north again. Does anyone know the charge tube ID so I can buy fittings to put together a leak tester today?
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
It is 2". I use this one and it works well. https://www.amazon.com/gp/product/B0825W6Z85/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
Hmmm, If only I had a few days before going back up north....
How harmful would it be to run the sled for a while with what appears to be a minor leak (down ~1psi from expected)? I know I am losing power, but for now that doesn't matter that much (still was able to bury every 850 doo in my group).
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
I ended up making my own tester, was able to fill up to 25PSI using my M12 inflator and it took ~45-60 seconds to bleed down with no significant changes in the speed it was bleeding off. This leads me to believe that what leaks if any I have are minor enough to not matter to the turbo...
Turboflash
- Mar 18, 2019
- Southern MN
Tested 2 '17 TCats over last weekend. I had a regulator so I could dial in 20 psi and have it hold that while I checked. Both leaked at 20 psi. Did the clamp spacer mod to both and re-checked. Both did not leak after clamp mod. (Shortened spacers to .175").
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I've been grinding them down to .135" and been much happier with the clamping on them. Its amazing that at stock .250" thickness that there is zero clamping force on them!
Mototown
- Sep 11, 2018
- Apex 40 th
2 1/8 refrigeration copper pipe works ,
Turboflash
- Mar 18, 2019
- Southern MN
Whatever works. Even at .175 we could see the spigots bulge when the clamps bottomed. Boost leak test at 20 showed no leaks. I know there's many opinions on how much to shorten the spacers.I've been grinding them down to .135" and been much happier with the clamping on them. Its amazing that at stock .250" thickness that there is zero clamping force on them!
- 18K
- 26K
- 9K
