Seems like the filter is pre oiled...sticky mess is filter housing..AND ON CLUTCHES AND BOTTOM OF BELLY PAN...Recommend cleaning clutches and belt with simple green or dawn..
The oil was everywhere
Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
Good info thanks
Does the manual tell you to oil the air filter? Never heard of that on a sled. Could it just be engine oil from the breather?
I think I would have hauled it back to the dealer. You are paying for pdi.
This was my first thought...but it was a gooey sticky yellow substance that didn't seem like any motor oil I've used and it was on the filter elements base that seals to the air box housing...with a zero mile machine barely ran...I can't imagine anything but filter oil....I suppose the fact they have a foam filter is telling..and those are usually oiled right? Either way...filter cleaner is going on mine and I'm running it dry until I devise a cai
checked the manual...says nothing about filter oil...hmmm
nadekeys
- Oct 20, 2009
- Green Bay, WI
2017 Sidewinder LTX LE
2009 Apex LTX GT
2008 Nytro MTX Turbo
I'll have to look at mine, thanks for the heads-up sj. Could it be your dealer saw the foam filter and figured it ought to have the foam filter sticky oil applied similar to an ATV? I sure hope mine isn't like that. I'd give your dealer a call and let them know the issue. Either way, if they did it by mistake or if they are coming like that from Yamaha dealers should get a heads-up so they can correct it before the customer leaves with the machine. If mine is a mess my dealer will get a call. I'll probably still clean it up myself though.
okay...mystery solved...apparently its on the dealer PDI to pre oil the filter..
HEY KID..MORE ISNT BETTER! lol
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
Must be oiling the filter now for extra protection for the turbo? I've never seen a sticky-oiled foam filter on a sled before this.
the 2012 and 2016 cat turbo's I had had a fabric element..this foam filter is different for sure...I guess they feel there's enough dirt in the air they need to catch it with the oil...plus it probably prevents snow/ice from sticking?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
22 Mach Z
23 Sidewinder SRX
With the air intake on the clutch side, I'm thinking that Yamaha doesn't want belt dust injested like Doo had with the 05-08 Mach Z
that would be a good thought...but the airbox is sealed and theres fresh air intake from the outside...but...I guess anything is possible..
If it's not in the manual I highly question whether it is on the Actual PDI. Will check next time I get to dealer. Good find SJ!
Goop on clutches cant be proper.
- 39K
