rb2001srx700
- Dec 17, 2015
- BALLSTON SPA
- 2001 SRX 700
Silly question. 2020 SR Vipers. Should we weld the tensioner bolts on them as well or is this just a winder issue?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
If it has the same set up as a sidewinder I would for sure.. Its the vibration/harmonics that gets the bolts going the wrong way.. Seems to be no pattern on this either.. Heard of failures with only a couple thousand miles - And others that never have a issue in thousands of miles +.. Its a must do on a sidewinder and see no reason it would not be on a viper IF it has the same roller set up?
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Vipers have the identical roller setup in the chain case. The roller screws should be tack welded for Vipers as well.If it has the same set up as a sidewinder I would for sure.. Its the vibration/harmonics that gets the bolts going the wrong way.. Seems to be no pattern on this either.. Heard of failures with only a couple thousand miles - And others that never have a issue in thousands of miles +.. Its a must do on a sidewinder and see no reason it would not be on a viper IF it has the same roller set up?
The 15 Viper that i used to have had green Loctite on the roller screws and they were not loose (but I welded them anyway). I got the sled with 46 miles but I was the 2nd owner and I know with 100% certainty that the 1st owner had the chain case opened up but I don't know if he did the green Loctite or if Yamaha did.
I got my current 17 Sidewinder with 340 miles. There was no Loctite on the screws and they were both backed out quite far.
WindTime
- Feb 14, 2022
- bracebridge
- 2018 yamaha sidewinder
has anyone tried the aftermarket skate instead of the wheel?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Not many on here are or they are not posting about it. Most are welding the bolts and having zero issue with the metal roller. Maybe the plastic skate would help with vibration? I would think it might. Just not hearing much on this site about it.has anyone tried the aftermarket skate instead of the wheel?
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
I would tack weld every adjuster in a Sidewinder, AC 7000, Viper, XF 9000, ZR 6000 and every one with this chaincase. Saw far too many busted chain cases for my liking this year. Especially when parts are on back order for months at a time.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
The adjuster bolts or the bolts that hold the wheel in the bracket?
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
The ones that hold the roller to the bracket
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
That was my understanding (the tack welding is to the bolts that hold the guide wheel in place, not the tensioner.)
but the two comments:
Question
" Should we weld the tensioner bolts on them as well "
Answer
"I would tack weld every adjuster in a Sidewinder"
Made me think "wait what?"
Jvji24
- Mar 1, 2022
- Wi lakes
- Tcats
Polaris
Anything that uses that case I have welded.
That’s an ugly breakdown if you dont
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
The tensioner bolt itself has a jam nut. Its just the bolts on the tensioner bracket that hold the guide wheel in the tensioner bracket that comes loose was my understanding. The bolt in yellow not 5,6 as shown below.
I just want to be clear as I am having the top gear and shaft done as preventative maintenance by a local weld shop and if something else needs to be done then do that at the same time.
Not to mention they aren't cheap. Just had to replace both halves on a Viper, around $400 each CADI would tack weld every adjuster in a Sidewinder, AC 7000, Viper, XF 9000, ZR 6000 and every one with this chaincase. Saw far too many busted chain cases for my liking this year. Especially when parts are on back order for months at a time.
Fords4life
- Dec 7, 2021
- South Dakota
You are correct with the yellow area.The tensioner bolt itself has a jam nut. Its just the bolts on the tensioner bracket that hold the guide wheel in the tensioner bracket that comes loose was my understanding. The bolt in yellow not 5,6 as shown below.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Ya - parts for these things are getting ridiculous.Not to mention they aren't cheap. Just had to replace both halves on a Viper, around $400 each CAD
MS
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
I saw somewhere, someone selling bushing for where the tensioner mounts on chaincase. Anyone know who and have you used it. Seems like a nice idea to keep from wearing.
- 7K
