lakercr
Tech Advisor
While we were going through the sled on Saturday trying to find the cause of a SD26 code, I noticed this:
Pstn head
Remove that shield and check the flex joint on the pipe from the manifold to the turbo. It's not a bad idea to remove it completely and inspect it for cracks.
Fleecer
- Jun 13, 2014
- 2019 SRX
Recall on that shield. Dealer changed mine.
Fast
- Sep 25, 2018
Are there any other recals?Recall on that shield. Dealer changed mine.
Fleecer
- Jun 13, 2014
- 2019 SRX
None that I am aware of.
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX (on order)
2018 High Country 9000
2001 SRX 700
Its a good thing to check at the same time if the flexible is not leaking. I had mine cracked in two pieces. Covered by warranty. Had to replace shield and gaz tank protective wraps.
Fleecer
- Jun 13, 2014
- 2019 SRX
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
2001 SRX 700
Yes i saw that great looking mod. The new shield was backordered when I ordered. I also did all the job myself. I am supposed to be picking up the new shield on thursday, so I will still have my old one.
Did you find it to lower the belt and clutchs temps by a good margin?
Fleecer
- Jun 13, 2014
- 2019 SRX
Yes! It is not the end all cure all, but another step in right direction.
- 6K
