Check your primary. Re-torque NEW SPECS 108 back off then 43 ft lbs
jonlafon1
Age
48
Mount Morris, WI. Chaney Lake, Upper MI eh!
2022 Sidewinder LTX_SE
2024 Catalyst
I took my primary off last night. The bolt was tight BUT when I put the puller in I was able to pop it off by just holding the clutch with my hand!. I know this kinda goes without saying(with new sled) but I would suggest people re-torque the primary.
108 pounds then loosen and re toque to 43 I believe. Correct me if I have this wrong?
**108 lb. then 43**
Not saying mine would have come off but man it was NOT nearly tight enough(pressed on). IMO
this is my first Yamaha clutch/sled but it seemed way to loose compared to taking off other clutches in the past.
krm
Age
68
ny
sidewinder 850 mxz,850xrs 850xrs 900t22Mach Z
mine did the same 3 weeks ago
NOS-PRO
"The Burnman"
Vendor
Hessel, Michigan
Sidewinder, SR Viper XTX, SR Viper XTX, 2016 Apex XTX and Pro-Line Pro Stock 1000
80 pounds then loosen and re toque to 45 I believe. Correct me if I have this wrong?
Yes, torque to 108 ft. lbs. , after clutch is torqued... loosen bolt and re-torque to 43 ft. lbs.
cannondale27
Staff member
Moderator
Vendor
Manitowoc,WI
Here is Torque specs for new clutches from Tech Update book
cannondale27
Staff member
Moderator
Vendor
Manitowoc,WI
Good catch. Could you edit to the new even tighter specs?
VX1R
Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
On the way: 2023 Lynx Xterrian 900TurboR
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
Q. Arrius
Age
51
Indiana, (central)
'17 Sidewinder LTX LE (red)
'12 Apex SE (black)
'12 Arctic Cat F800 snopro (129, orange)
'15 SRX 120 (blue)
''15 S.Doo Renegade XRS (Ronald McDonald colors)
Does this mean the sleds are coming off the line, with the primary too loose, and should be checked across the board?
Q. Arrius
cannondale27
Staff member
Moderator
Vendor
Manitowoc,WI
Q. Arrius
No it means the torque specs for the new clutch is higher than the old clutches. Maybe Cat doesn't know that though.
cannondale27
Staff member
Moderator
Vendor
Manitowoc,WI
Steve...is there anything in the new Tech Update book that addresses the belt ride height in the secondary clutch for proper belt tension?
There is. I will get that if no one else does. Is no spring specs and such like in past with new. I still don't agree with setting Deflection on stand other than to get close. It's so easy now. Do in the snow and get it tight as possible without creep or squeal. That's the best way.
cannondale27
Staff member
Moderator
Vendor
Manitowoc,WI
Thanks for the UPDATE on torque specs Cannondale.
I would strongly suggest guys re torque seeing these new specs.
Yes I have a uneasy feeling that you found something here. None of us had a clue till this update came out. Hopefully Cat also got the update before they were built. Personally would not count on it.
jonlafon1
Age
48
2024 Catalyst
No way My clutch was torqued to the new specs. Maybe mine was random BUT...
And its not like the bolt was loose. So no need to panic but a simple re torque is easy enough
cannondale27
Staff member
Moderator
Vendor
Manitowoc,WI
I put this in FAQ at top of list. Is all we can do. Thank You Jon so many here are always observing and thinking,willing to share. Makes this the best site on earth!
