Checking gear oil
kimoajaj
Norway
I was just wondering how I should check the gear oil? Where should the oil level be on the dipstick?. Should the pin be screwed in or should it only rest on top of the hole? .
There are no lines, only the letters "revers" (the dealer said that I should use that side since I have reverse ) .
there is two separate levels, one for reverse and one for standard. Obviously use the correct line and push the dipstick all the way in.
Gees, I didn`t mean "screw it in" , it doesnt have threads hehe:) , I simply forgot.
Hmm we didn`t see a line..
On my friends venture the oil barely climbed a 1mm on the dipstick, so I guess he could pour some oil into his chaincase then:).
I guess it`s OK as long as the oil is within reach of the dipstick.
