qubert
I have a 2007 apex, and at slow speeds im noticing a chirping and wherling sound,at of near to the secondary clutch area . does anyone know what im talking about . or does this sound familiar... belt is like new and has almost no wear, at all , un even or otherwise.
sgauthier
Did you remove the shims in the back of the secondary when you put in your new belt? Belt might be too tight
qubert
Nope .. just put a new factory yamaha belt on at the begining of the season its been fine . not giving me any trouble . i thought it might just be the belt aswell . but i only hear it at really slow speeds. .Did you remove the shims in the back of the secondary when you put in your new belt? Belt might be too tight
thought it may be jackshaft berring . but its a new sound to me . and only started hering it recetntly. and its only under load . if i lift the track. and push on the throtle there is no sound
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Remove the belt and try to move the secondary around to check for bearing play, or remove the secondary and look at the bearing,
