Alsim
- Oct 6, 2014
- LTX SE 2018
any trick for cleaning aluminum on the outside of the oil case, clutch. somes stuff like sandind or acid?
TD Max
I believe that is a magnesium alloy and it's got a pretty coarse surface finish. Best I can say is powder coat it if it bothers you. Clutches leave as is. Belt shield and tie rods try Magic Mix metal polish.
True. If it does bother you Eagle One Mag wheel cleaner works real nice. Just dont let it sit on there to long since case is thin already!I believe that is a magnesium alloy and it's got a pretty coarse surface finish. Best I can say is powder coat it if it bothers you. Clutches leave as is. Belt shield and tie rods try Magic Mix metal polish.
Mitch Desorcy
MAX PRO
- May 6, 2014
- Winnipeg Manitoba
- 2014 Yamaha SR Viper LTX SE
Try oven cleaner on the coarse magnesium and aluminum. Spray on leave for 15 minutes and wash off.
Alsim
- Oct 6, 2014
- LTX SE 2018
Thanks guys !
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Spray oven cleaner on the clutches? Will it clean them right up? I've been trying to get a Viper clutch I bought cleaned up and it's not cooperating lol!Try oven cleaner on the coarse magnesium and aluminum. Spray on leave for 15 minutes and wash off.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
Weren’t guys using there wives Dishwasher ! It does work wondersSpray oven cleaner on the clutches? Will it clean them right up? I've been trying to get a Viper clutch I bought cleaned up and it's not cooperating lol!
