lilrez
Want to replace the 5/16 Clear tubing used for the oil level.
Is it vinyl? Ok for oil?
Turboflash
- Mar 18, 2019
- Southern MN
Vinyl not ok. Urethane only.
lilrez
Thanks .
lilrez
No luck at Crappy tire or HD or amzn.ca. ... May try TSC.
Didnt check my closest dealr..they dont carry much in Stock
Turboflash
- Mar 18, 2019
- Southern MN
Dennis Kirk, ShadeTree, McMaster-Carr, Bell, Bikeman, Turbo Dynamics, etc.
Kevin
What's wrong with the original one?
lilrez
Just discoloured from 10000kms of use. Would like it to be clear again to make it easier to perform a quick visual
jjmoneysauce
- Jan 14, 2018
- 2018 VK540
And some Bravos
And some Enticers
In almost all applications, it is best to get the OEM line from the dealer. It is often pink Tygon. 6.5mm ID and 11 mm OD.
any local small engine place you could try? heck there must be a kimpex dealer somewhere by you that could get it for you.
lilrez
Yep.
For this application its 7.94IDX11.11OD
jjmoneysauce
- Jan 14, 2018
- 2018 VK540
And some Bravos
And some Enticers
Have you tried the dealer? Be careful of aftermarket lines!Yep.
RAMSOMAIR
Just looked up the price of that oil line on the fiche, $80.50CAD, retarded.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Try cleaning it? Instead of replacement.
