SidewinderConvert
4-Stroke Rookie
Has anyone tried this yet? There is a station around the cabin where I could get E85 for the sled. If the closed loop works the way I think it should (add fuel until lambda = 1) and you have enough overhead in your fuel pump/injectors everything should run correct right?
I would think the biggest issue is going to be startup and the few seconds of idle before the O2 sensor starts working and closed loop activates.
