snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
I just took out my 2008 nitro and I have the expert x 144 installed, have had it in now for a few years. I noticed at slow speeds a clunking by my left foot today. go fast and it goes away, slow way down and there it is. anyone else have that problem? no ice build up, right off the trailer it started to do it. I looked at everything and it all looks good. any info would be great.
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
I would check your belt first! She might be getting ready to blow.
snopro442
- Dec 10, 2007
- neenah wi.
not to sound dumb but how would that give me a clunk by my left foot????
R00STER
- Mar 3, 2013
- Timmins, Ontario
Blew my belt last week. Just before it went I was vibrating like I was running a 3" track. It was a lot worst on the left side.
snopro442
- Dec 10, 2007
- neenah wi.
ok. I will check it out tomorrow and see what it looks like.
snopro442
- Dec 10, 2007
- neenah wi.
belt still looks like new, no damage. I checked the susp. over and cant see and broken parts.
sledheadgeorge
When is the last time you rebuilt the shocks?belt still looks like new, no damage. I checked the susp. over and cant see and broken parts.
snopro442
- Dec 10, 2007
- neenah wi.
the whole skid has under 500 miles on it, I had it since new. I plan on taking it out this Saturday and I will try a new belt.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Check both set screws in the left side drive bearing collar. Also you may need to reset the collar if they are loose. You can get to them from under the sled. I have seen 2 of these loosen on Apex's causing the exact noise you describe.
snopro442
- Dec 10, 2007
- neenah wi.
I looked them over and they look good and the white plastic part around the bearing is still good.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Make sure the set screws are tight. the bearing doesn't go bad, the set screws come loose.
snopro442
- Dec 10, 2007
- neenah wi.
ok I will check that out tomorrow after work when I have time, thanks for the help.
snopro442
- Dec 10, 2007
- neenah wi.
snopro442
- Dec 10, 2007
- neenah wi.
I replaced the bearing and both set screws and rode it all day yesterday without any noise. hopefully that was it.
stubb111
a little off topic but, I was wondering how you like the expert x 144 and how it performs???
