Clutch alignment and belt height
Reaper
Starbuck, Manitoba
Canada
2014 SR Viper XTX. COTC, Hygear 141 pro link.
Checked my alignment between secondary and primary and I was at the outer limit 61.1 mm.
Spec is 58.1 mm to 61.1 mm. Removed the 1 mm shim from behind the secondary and I am now at 60 mm.
This also brought up by belt height to the bottom of the cog being 1 mm above the sheath (secondary off the machine and fully closed and belt lying in it). With secondary on the machine I probably have 1 mm from sheath to top of the cog on belt.
It ever so slightly creeps on the stand so believe that should be spot on correct?
I would leave it at 61mm from the testing i have done. I also run deflection even with top of secondary. I have found this works better on the new clutches. Track doesnt need to creep.
OK, Thx Shagman.
