Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
Fully clipped 1.25 rip 2what changes...forget that it did it from zero
list the changes
144 triggers
6.9's
Transfer blocks removed
Cai
Belly pan protector
Max 17 tune
Dalton springs & weights
Stock helix
Handguards
Retorqued primary
Sealed left side belly pan with silicone
I'm sure there's more I forget
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
How is it blowing belts? At speed? Delaminating? Snapping?
Whats your secondary wrapped to? 6-1 with the dalton black orange?
Thats a ridiculous amount of belts.
Soupy
- Jan 10, 2017
- West Michigan
Belt is hot all the time, all it takes is the right WOT for a few seconds and booooom! Its delam, not clean break. 6-1 Dalton b/o currently but same results with every secondary setup I've tried.How is it blowing belts? At speed? Delaminating? Snapping?
SuperTurbo
- Mar 20, 2004
- Amherst, Ohio
- 17 LTXse Sidewinder
Did you ever try a diff primary clutch?Belt is hot all the time, all it takes is the right WOT for a few seconds and booooom! Its delam, not clean break. 6-1 Dalton b/o currently but same results with every secondary setup I've tried.
Soupy
- Jan 10, 2017
- West Michigan
Yes from a known good working winder.Did you ever try a diff primary clutch?
ShootToThrill
If you were closer you could try my apex primary and my winder secondary as a set. 123 degrees on my last trip.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
your weight? gearing?
Soupy
- Jan 10, 2017
- West Michigan
280your weight? gearing?
Stock ltx gearing
