redman
I am looking for a little help with my clutch. I will admit I have no idea when it comes to much mechanical let alone the clutch. At idle my primary rattles until the point the rpms come up and it goes away. I took out the 6 bolts from the cover holding the spring in. There seems to be quite a bit of play. Any suugestions would be appreciated. Thanks.
Convert
- Apr 14, 2003
- Lakeville & Nevis, MinNoSnowta
Pretty much normal about all you can do is up the idle a little to quiet it down.
hardcore2
Yep---We all rattle at idle..
