Clutching for 8000-10000
Stone9
Quimby, IA
2013 Nytro XTX
Below are my mods and current clutch setup is stock except for 14.5 mm rollers,47 degree helix, and green-pink-green primary spring. I need a starting point for 8000-10000 feet. Any help is appreciated.
Ok sounds like remove all rivets and add either 10.3 steel or 13.3 steel to outer hole.
I would like to hear from others to see if this is correct
Sounds about right. For stock sleds they recommend empty weights for that elevation. They run pretty good even if your short a few rpm. A lot better then bouncing off the rev limiter.
Stone please share your engagement rpm and wot rpm or peak. I am also at 10,000 feet in Colorado. Why did you change to 14.5mm rollers, I am still running stock. I want to also get the most out of my clutching lots to learn.
MTX 153" with 3400 miles....
