mopar yam
- Nov 10, 2011
Hi guys here's what have and looking for a little input, 06 apex gt 121 96 studs ,stock weights with BOP primary spring ,secondary 51/43 helix from bender with TP orange spring at 50 wrap and 23/38 gearing . Ok when I hammer it out it flashes up to 10gs then slowly climbs to 10500 and no more on hardpack should it turn a little higher then 10500 or is this high enough? Thanks
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
You are close.
Another 10 degrees wrap on Secondary probably will give you up to 200 more.
mopar yam
- Nov 10, 2011
Going to be tight getting that spring to 60 !
Winderallday!
I use an adjustable spanner pin wrench to wrap the helix, use the empty helix spring holes. Works slick
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
That’s brilliant!!!I use an adjustable spanner pin wrench to wrap the helix, use the empty helix spring holes. Works slick
