swamp hog
- Dec 25, 2010
- Huntsville, Muskoka
- 2014 Viper LTX SE
4600km - 2014
Took my first ride with my Turbo MPI trail kit. Did 216 miles and things worked great.
I have super tip clutch kit. I added 11 grams in the heel, two grams mid and 4 grams at the tip. Using stock spring in primary. The secondary is set at 3/3. The original clutch kit came from Ulmer racing.
It hits hard down low and pulls hard all the way to 85-90. Max RPM is 8,300 then falls to 7,800.
Any ideas?
Any ideas?
Threeman03
- Nov 1, 2015
- Flushing,mi
- 2016 Yamaha sr viper ltx LE
Sounds like you have to much weight .Took my first ride with my Turbo MPI trail kit. Did 216 miles and things worked great.
Any ideas?
11 grams in the heel ? That's a lot. How much are your weights currently weighing?
I would put 3 grams in heel and zero in the mid and keep 4 in tip.
Mitch Desorcy
MAX PRO
- May 6, 2014
- Winnipeg Manitoba
- 2014 Yamaha SR Viper LTX SE
Call Ulmer?
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
I have the Ulmer/MPI clutch kit and if I remember right I have 3 washers in the top and 3 in the bottom none in the middle. I have a 16xtx trail turbo and don't have the issues you have stated.
titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
Any ideas?
Is this a kit for a stocker that your trying to use with the Turbo?
swamp hog
- Dec 25, 2010
- 2014 Viper LTX SE
4600km - 2014
I have the Ulmer Clutch kit. I emailed him and he gave me the current weight set up. The clutch was machined and set up by Ulmer for my Viper when it had the can,tuner and intake. I have emailed him again, but was hoping to get feed back from guys that have the set up.
What top speed are you seeing and top RPMs?
titanrcr
- Jan 3, 2011
2015 Viper LTX SE
2011 Apex
You will most likely need a different helix and secondary spring now with the turbo
swamp hog
- Dec 25, 2010
- 2014 Viper LTX SE
4600km - 2014
The helix and secondary spring are the same. Just wondering if anyone knows the base weight of the cam arms. The ones I have are 50 grams. Wondering what the turbo base weight is that comes with the turbo clutch kit is?
09nytro
I'm pretty sure they are 60 gram base , I will double check when I get to work !
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
The base weight with the tubro is 60g. but you should be able to make the 50g work.The helix and secondary spring are the same. Just wondering if anyone knows the base weight of the cam arms. The ones I have are 50 grams. Wondering what the turbo base weight is that comes with the turbo clutch kit is?
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
It sounds like he had the 50g SuperTips before he was turbo'd. With his current setup hes at 67g.
How old are your springs Swamp?
swamp hog
- Dec 25, 2010
- 2014 Viper LTX SE
4600km - 2014
The springs have about 6000 miles on them. I am guessing I have to much weight. I think I will remove the 2g from the middle and 2g from the tip.
tapex_07
- Feb 15, 2009
I would get new springs in there to start. Then I'd pull 1 from each location and see what it does.
09nytro
Turbo set up with ulmer kit that we have
Perimary and secondary spring that Allen supplied and Helix K
60g weights
3 washers +o-ring in heel
None in middle
2 washers+o-ring in tip
60g weights
None in middle
swamp hog
- Dec 25, 2010
- 2014 Viper LTX SE
4600km - 2014
Great, Thanks this is what I was looking for. Do you know what colour springs you have? What turbo kit do you have?Turbo set up with ulmer kit that we have
60g weights
None in middle
