Clutching or Regearing
Hev
Saskatchewan
Im looking to get some more bottom and midrange pull from my '10 Nytro XTX. Do you think I would be better off just dropping the top gear one tooth, or installing a clutch kit? I was thinking about a Drag N Fly kit if I go with clutching. I dont care if I lose top end speed, I just want more pull.
Well i have a rtx se and i did both , 20/40 gears and clutch kit and still getting 98 mph on hard packed
Drag N Flys with Turks black spring setup will give you what you want.
I have a set of drag n flies set up for a nytro for sale . $160 canadian shipped from manitoba.
about this black spring.....is this a yamaha black spring or is it the one that comes in the kit? I have the one that came in the kit....
