machz69
Well it's just about that time again and I still haven't done anything for clutching, so I'll ask for a little bit input. So far Im going to be ordering the shock wave variable cam and I'm guess a set of super tip weights, how much weight?. What should I be looking for as for primary and secondary springs?
Turk
Tech Advisor
I would stay away from the shockwave...more negatives then benifits. Primary weight is impossible to give you a number on unless you tell us how much boost your running & even then it,s gonna be a shot in the dark.
I have had great success tuning turbo,s with a stock or close to stock helix running 20/50 2 speeds up to hi-teens in boost.
machz69
Oh yeah?.. I thought that cam was good? I hear you on the weights, im not looking for the actual weight but more, is there different type of them weights?.. as in adjustable from 60-80 or from 70-90 type thing. as for the boost well right now it's 8lbs
Turk
Tech Advisor
swe_mike
- Mar 29, 2010
- north of sweden
- www.mcx.se
hi turk!
what degrees on the stock helix are you talking about? And why are the shock wave helix bad? what kind of spring are you using in your secondary clutch?
Many questions... sorry
Turk said:Way way back when i was running 8-10 pounds boost i used heavy hitters loaded to about 68 grams & a helix close to stock.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Apex stock helix 51/43 which I believe measures around 48/42 sec spring white...typical wrap 6-1..
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
I do always use yamaha helixes too. but not always stock apex, I use a few of them depending on conditions and snow
