yamanytro121
getting a crankshaft sensor code on my 09 RTX SE. sled doesnt even wanna turn over, i replaced the stater solenoid and still nothing. getting good amprage coming of the solenoid to the starter. just wondering if there is anything out there in perticular i could check. i already checked over the harness and there isnt anything out of place or rubbed through.
:exc:
:exc:
207nytro
Had this the other day after installing my extension kit, luckily as soon as i turned the key over the code went away. Best advice is to check the harness all the way to the actual sensor, if you have not already. if not the other information i have found on testing is that the sensor should have around 500 ohms as 68 degrees. Also, check all connections as well as the wiring, a corroded pin may be the problem. The wires to the cps are the black/blue and the grey wires coming out of where the stator is. Search function helps a lot.
yamanytro121
im wondering if it isnt a starter issue for some reason. when i disconect my buddies sensor on the same sled it still turns over. im getting like 450amps going to my starter and it just loads everythihng down. the engine isnt locked though because it can be turned by hamnd no problem.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
You'll get code 12 if the engine doesn't turn over when the ignition is in start position. If it's not turning over follow this: http://www.ty4stroke.com/viewtopic.php?p=931403#931403
yamanytro121
Do you know where the starter is grounded at?
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Starter is grounded to the engine block. Yamaha had a problem with starters staying engaged after the engine starts which is caused by a faulty starter relay. If this happens it'll destroy the starter. Sledstart sold indicator lights that warned if the relay malfunctioned.
yamanytro121
yea i just replaced the start relay about a week ago. then had the sled parked outside my garage for a couple days and when i tried starting it again that was the beggining of my troubles. ill have to check the condition of the ground conection. if nothing else ill pull the starter out
i had to jump the starter relay a few times whent he old one failed so that might have paid a big factor in this issue
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
jumping across the relay will not hurt the starter. Can you still jump across the relay and start it? follow the diagnostics link I gave you.
yamanytro121
nope if i jump it across the relay it just loads up the system as if i were turning the key
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Check the wire between the starter and relay for a short. If that's OK then most likely it's a bad starter.
yamanytro121
thats what its looking like. thanks for the chart and tips.
