@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
hi that code sd85 shows up this morning on my sled do you guys had any issues with that and how to fix the issue and i know its the oil pressure switch . thks
BlueApexXTX
Hey Medic.. You ever figure out what set the code 85 0ff?hi that code sd85 shows up this morning on my sled do you guys had any issues with that and how to fix the issue and i know its the oil pressure switch . thks
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
look under your primary clutch they’re 2 plug in a black and just behind they’re a white plug in , unplug them put some electrical contact cleaner in them and blow it off and put some dyelectrical grease in you must have humidity inHey Medic.. You ever figure out what set the code 85 0ff?
BlueApexXTX
Had mine flash this weekend,Sled ran fine.. The code went away after turning the key on and off a few times. I will check those connections tomorrow and clean them up.. Thankslook under your primary clutch they’re 2 plug in a black and just behind they’re a white plug in , unplug them put some electrical contact cleaner in them and blow it off and put some dyelectrical grease in you must have humidity in
RTX Meirda
Happened to me today as well. Did this clean up of plugs help everyone?
fourload
Mine just started giving me a SD 30 yesterday after a fast lake run yesterday(oil pressure) . The sled shut down and rolled to a stop. Checked the oil level which was perfect and restarted it and rode slowly to my dealer. It ran and sounded fine. He confirmed the code 30 and ordered a new pressure sender and a new pressure switch for me because he said he he didn’t want to chase the problem by replacing one of them and possibly having the other still bad. The two of them are interrelated. Glad I have the extended warranty because the sender is $215 and the switch is over $50. Till then he told me to run it. Hopefully it fixes the problem.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
I got this code yesterday
Anything to worry about or just clean the connections?
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Guess this isn't a popular fault code
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
append to me last year clean your connection and be sure to hear a click sound when you put it back onGuess this isn't a popular fault code
fourload
These sleds have a sender and a switch. I got a sd30 which is low oil pressure. It shut the engine down. Really freaked me out. My dealer replaced both the sender and switch just to be sure. If you are still have a warranty let the dealer diagnose it. The switch is cheap but the sender is like $200. You could try the wires first. Probably you only have a bad switch since your code is a sd85.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Hopefully just a connection as I am way out of warranty
I figured if it was something major other lights would have went off or motor would have shut down
Have to ride it 40 miles back to the trailer and it didn't go boom....lol
