Kuches
- Jan 8, 2017
- Illinois
- 2008 FX Nytro
2008 Nytro red light stays on continuously after startup and doesn't go off. I checked radiator and I can not see any coolant in there. I poured some coolant into the radiator and it immediately started flowing onto the ground. I checked upper hoses and do not see any obvious leaks and am hoping it is one of the lower hoses popped off. Question is removing the skid plate the best place to get in there and see where it is coming from and does anyone know of any spots that are known to leak? Thanks.....
If you pull all the plastic on the Nytro it will expose the entire front clip and you should be able to see everything you need to find the leak.
