dirkdiggler
Suspended
Has Anyone thought about hooking the Radiator fan directly into a hot power source with a switch. That way when you get into questionable conditions you could just flip the switch to cool the sled.
AS I understand it the fan only comes on when the coolant is a X temp.
This would also be a great Idea for Asphalt and Grass dragger's.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
This is done alot on street bikes and off road 4-stroke dirt bikes.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The idea of just using that little radiator for asphalt/grass is a great idea, but ultimately it's not large enough to keep it cool. Especially in the location it's located in. Just my .02!
dirkdiggler
Suspended
Srxspec said:The idea of just using that little radiator for asphalt/grass is a great idea, but ultimately it's not large enough to keep it cool. Especially in the location it's located in. Just my .02!
Sure allen shoot me down.
http://www.ty4stroke.com/viewtopic.php?t=15800neonphil wrote: I returned back to the pits after making my pass, my water temp was 140 degrees. Normally it would be above 220.
I think they should run the coolant through handle bars with a valve you can set for extra cooling and the very best hand warmers around.
Yeller
Sled Dog said:I think they should run the coolant through handle bars with a valve you can set for extra cooling and the very best hand warmers around.
Now that's a great idea!!
