PureBlue
Anyone use CR10EK in the FX Nytro yet.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
PureBlue
Any testing with the CR9EK or is it the same, just a little hotter.
SharkAttak
Srxspec said:
Allen, would the cr10ek work in the phazer's also? to give it more h.p.
- Apr 17, 2003
- Menno, SD
- Menno, SD
PureBlue said:Any testing with the CR9EK or is it the same, just a little hotter.
CR10EK is better than the CR9EK in the FX Nytro.
- Apr 17, 2003
- Menno, SD
- Menno, SD
SharkAttak said:Allen, would the cr10ek work in the phazer's also? to give it more h.p.
Leave the stock plugs in the Phazer. It already has issues with fouling plugs and hard starting, you do not want to go to a colder plug in the Phazer.
NyTrOMaNIaC
Allan, is there a need for a special plug cap on these plugs in order to install these in the FX Nytro, or are they a different set up than the Apex and Attak sleds ?
- Apr 17, 2003
- Menno, SD
- Menno, SD
No need for special screw on terminal on the top. Install them just as they come out of the box.
SharkAttak
Srxspec said:SharkAttak said:Allen, would the cr10ek work in the phazer's also? to give it more h.p.
thanks Allen, my phazer fx is in the shop right now having the cold start update done
lucky_7
What is the latest with this? Can anyone give a real world update?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Been working great out in the field so far. For $24 it's a decent gain (1/2 a sled length gain vs stock).
- 13K
