mx1500
i cut my windows a fair amount. sliders easily fit and i didnt burn the edges of the track or anything. tracks been like this for 3 years now and its fine.
Blue Dave said:I do not like the word "weak". That is what I am trying to avoid. If this weakens the track enough to have to offset the weakness I may decide to pull the skid again for peace of mind with my new track.
Has anyone actually experienced an adverse effect like tearing from doing this?
IA Rider said:MadMax said:X2............... Never had a problem....................... "EVER". MM.Grimm said:I still don't understand the need to do this...I've never had a problem fitting a set of sliders through the track windows, just insert the slider through the track window vertically and twist 90 degrees. It just requires a little extra force, and maybe a little lube.
X3
DigitalFusion said:mine have been cut on my ice ripper for I-dont-even-know how many miles with no adverse effects. The best part of doing it this way? getting the slide a bit out of the windows, starting the sled, putting it in reverse, and watching the hyfax slide out without any pulling!
YammyRX1 said:Maybe a little late but if you chamfer the rear end of the new slides a little bit they will squeeze through the window easier on the next change...but that will be 10 years from now with Duponts, right?
