SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Looking to buy used helix but seller doesn't know angle/angles. Dalton helix with numbers 0130 stamped on it. Called Dalton, no help. Any ideas anyone?
I have been buying Dalton helixs for Yamaha secondaries probably as long as Dalton has been selling them. I have always purchased them directly from Dalton or one of their distributors and I have never seen one that doesn't have the angles imprinted on the helix.
If it really is a Dalton helix it must have been custom ordered for someone selling clutch kits that didn't want anyone to know the angles...another reason I have always built my own kits as how can you dial in your clutches if you don't have the numbers to do the math?
One exception to my rule is Ulmer as he will tell you what his angles are if you need the info.
SideHogger
- Apr 16, 2016
- upstate ny
No angles stamped in it, must be special cut helix. Is their a way to measure it? BTW, Dalton stamping is on it.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Like sideshow said, it's likely from someones kit and they don't want you to know their angle.No angles stamped in it, must be special cut helix. Is their a way to measure it? BTW, Dalton stamping is on it.
SideHogger
- Apr 16, 2016
- upstate ny
I'd say you're right but is there a way to measure it to find the angles on it?
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
Roll it on a piece of paper tracing the curve with a pencil, then use a protractor to measure it
SideHogger
- Apr 16, 2016
- upstate ny
Thanks Tcat100. I knew it couldn't be that hard but when you aren't very bright...........lolRoll it on a piece of paper tracing the curve with a pencil, then use a protractor to measure it
I don't have a protractor on this property, can anyone tell me what a dalton 3310 helix is?
It also reads SIDE 205.
The angle digits have been ground off, top secret clutch kit of course!
