SanDale Fabrication
- Jan 14, 2015
- 2017 998 turbo
We always get questions in regards to how loud our mufflers are. Seeing that we produce the product I feel it is always better to have someone else share their results.
Allen Ulmer has done this test and shared it with me and I will now share with you. Please note the HeartBreaker has not been done yet and nor has the New SanDale Outlaw Muffler
Decibel Testing
Stock @ idle 73.5 decibels
Stock @ 2500 rpm 81.1 decibels
Stock @ 5000 rpm 91.2 decibels
Stock @ Wide Open Throttle 102.3 decibels
Mod Stock @ idle 76.0
Mod Stock @ 2500 rpm 81.4
Mod Stock @ 5000 rpm 93.9
Mod Stock @ WOT rpm 102.8
2.5" Superflow Muffler @ idle 78.8 decibels
2.5" Superflow Muffler @ 2500 rpm 83.2 decibels
2.5" Superflow Muffler @ 5000 rpm 93.6 decibels
2.5" Superflow Muffler @ Wide Open Throttle 103.7 decibels
3" Hyperflow Muffler @ idle 82.9 decibels
3" Hyperflow Muffler @ 2500 rpm 88.6 decibels
3" Hyperflow Muffler @ 5000 rpm 96.8 decibels
3" Hyperflow Muffler @ Wide Open Throttle 106.6 decibels
These were all taken at the exact same distance (13 feet from the sled) on the same day.
Thanks Allen for the report, always appreciated!!
Mike
Decibel Testing
Mike
DooZ
Thank you...that is excellent informationWe always get questions in regards to how loud our mufflers are. Seeing that we produce the product I feel it is always better to have someone else share their results.
Decibel Testing
Mike
Mototown
Looks like the superflow is marginally louder than stock ( no exhaust noise when riding at speed ) How loud is the hyper flow or heartbreaker when cruising down the trail ? Can u hear the exhaust while riding sled ?
SanDale Fabrication
- Jan 14, 2015
- 2017 998 turbo
There is a noticeable difference at idle between the SuperFlow/HyperFlow vs stock. Cruising speeds, you do hear the HyperFlow and the HeartBreaker cannot be fooled as it is loud.Looks like the superflow is marginally louder than stock ( no exhaust noise when riding at speed ) How loud is the hyper flow or heartbreaker when cruising down the trail ? Can u hear the exhaust while riding sled ?
Set up 2 machines today, one with the SuperFlow and 240R Hurricane Flash, the other HeartBreaker and 270R Hurricane Flash... you can't hear the SuperFlow running over the HeartBreaker.
Have to point out, received flashes within 20mins of sending the ecu info! Thank you Ryan at Hurricane for the exceptional customer service!
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Just went on the first ride with the heartbreaker. Snow conditions are like driving on concrete which I think does very little to deaden sound I find it way to loud. Even with ear plug. My opinion it’s even to loud to enjoy it’s awesome sound
Seat of the pants Dyno I think it really rips compared to the hurricane mountain 2.5 that I replaced. It will be going back on. Going to try it on my MTX but most likely going to be for sale in the future
To bad cause it feels really strong power wise
earthling
I was curious what the the difference in db as posted previously really should sound like if we compare the other mufflers to stock. (using previously posted numbers).
The 3" muffler is really a lot louder. The left (vertical axis) is a conversion from the difference in db to how you perceive that as loudness (6db = perceptually twice as loud), the horizontal axis is RPM. When you look at just db numbers it doesn't look like a lot, hence this graph.
e.g. the hyperflow is a little over 3x louder than the stock muffler at idle although at those volume levels we aren't as picky. The stock modified muffler has a bit of a peak at 5000 rpm. Wide open (using 9000 rpm as a proxy) the 3" muffler is about one and a half times as loud as the stock muffler.
(the stock muffler value was set just above zero value for the purpose of the graph, so the blue bar showed up, all other numbers are relative to the stock muffler)
Still a little confusing but then audio always is.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I like the actual sounds tests better.
We get to hear the sound.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
This is the LOUD Heartbreaker muffler.
This is what the Yamaha srx with Hurricane 290hp trail package looks like. This is running the Sandale heartbreaker muffler ,290hp flash and hurricane... | By Hurricane Performance Canada Inc | Facebook
fb.watch
earthling
This is what the Yamaha srx with Hurricane 290hp trail package looks like. This is running the Sandale heartbreaker muffler ,290hp flash and hurricane...fb.watch
I hear ya
I was just looking for volume levels. I agree on listening for the sound (what it actually sounds like) in a video and you can more easily pick up on tone, drone, etc..
An example
In that clip the difference in volume is minimal. Yes, one is louder than the other but nowhere near what the volume difference is in person.
In that clip, despite the db measuring higher with each progressive exhaust upgrade the recording device actually makes some sound quieter. That is nowhere close to the real world (as far as volume goes).
Weatherbyman
- Dec 31, 2017
- Northern Wisconsin
- Apex, Vmax4
3 decibels is double the sound pressure. That’s the mathematics. The common log of 2(double) is .301. To convert to decibel multiply by 10 and it rounds to 3.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Soooo true.In that clip the difference in volume is minimal. Yes, one is louder than the other but nowhere near what the volume difference is in person
Video clips are deceiving. for one, you not ON the sled listening to it. The sound is totally different
I ran one of those Excell exhaust's for 2 days. End of the second day, I said "no thanks" In the audio clip the difference is not as bad.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I had a 3" Sandale Heartbreaker muffler for one ride this year. Took it off the next day and sold it.
We all know video clips don't give the actual sound of the muffler like your on the sled.
Don't need no board room graphs.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I just want know which performance muffler is the quietest?
Actually I know the PEFI muffler is the quietest, just not the best for power
Is the old adage "you cant have power without sound" still true after all these years?
earthling
yep, but double the power isn't double the apparent volume, that requires 10db which is what I
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
When a quiet 3" performance muffler shows up that makes awesome power I'll put my money up.
