rx1 fern
I am looking for some info on how to eliminate the fuel flashing symbol on my rx1 gauge . I went with a differnt setup for racing and not using the front mount turbo gas tank . I know there is a diode that people were using to get rid of the flashing symbol. Thanks for any advice also .
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
I used sportster dans post and it worked great. https://ty4stroke.com/threads/pro-rmk-front-on-nytro.114304/page-21
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
You need to find out what what ohm range the the fuel sender works at and get a diode that is in the middle of that range and then wire it into the sender to gauge wire. If you get it in the middle your gauge will show about a half a tank and the low fuel signal won't come on.
Ken..........
Ken..........
rx1 fern
Would a 100 ohm one work . Seen a post on a search about 100 ohm . Thanks
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
I don't remember what I used. I would take an ohm meter and check the sender and see what the difference is between full and empty and go from there.
Ken............
Ken............
