Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
If you have a 2019 and newer, you can easily add a 4th wheel for around $20.
I found this out from scrolling microfiche for 2020 and newer Arctic RXC race sleds.
You need 3 parts
-wheel mount 4604-380 $3
-spacer 4604-349 $ 3
-4th wheel 4604-423 $20
Basically you are changing out that larger spacer and putting in a smaller one between the center wheels and An additional wheel mount (plastic spacer with adjuster hole). You won't need the washer anymore either.
Cheap way to get 4 wheels in the back axle instead of 3 from factory!
You can look up the microfiche for 2020 and newer Arctic cat RXC to see how it goes together.
You need 3 parts
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Cool. Problem is though you still have the crappy wheels. They are 8 inch new, seen some that are now 7.5 after a season and others that totally blow apart
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
May have to look into this, been waiting for JT to bring something to market but as of now they don't have anything ready the last time I talked to them they were waiting on parts.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Hurricane has a nice 4 wheel kit with quality wheels
TPAY243
- Apr 14, 2013
- Northern Wis
So I looked at the microfiche 2020 RXC and it's showing 4604-322 for the idler wheel. Where did you come up with 4604-423?
no1b4me
- Dec 31, 2016
- 2019 ZR9000 Ltd iACT
That is a typo.... the correct 8" wheel AC part number is 4604-323 for 19' and current .......
TPAY243
- Apr 14, 2013
- Northern Wis
You are correct Thanks
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I have 4th wheel spacer kits machined that allow for use of 8" wheels with wider 6205 bearings inside the wheels.
Online Store (barnofparts.com)
Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
- 2019 Yamaha Sidewinder X-TX LE 141
I just installed two kits from J&T for a 2019 SideWinder - he's got them in stock, but people are scooping them up faster than they can be made.
JT has them in stock.May have to look into this, been waiting for JT to bring something to market but as of now they don't have anything ready the last time I talked to them they were waiting on parts.
8105450066
JT Products has had this super duty on the market for a couple years now with great success!! We use the large 6205 bearings in our stealth wheels kits we have been using for 8 years. All aluminum spacers for the best kit on the market!! fits 2019 129's and 137's. Fits all 2020 137's We have the kit for the 146's also. Lots in stock so get them while you can!!
8105450066
8105450066
TPAY243
- Apr 14, 2013
- Northern Wis
Do you have kits in stock for the 2020 137 the last time I called you where waiting on parts of something.
Yes is in stock for now.Do you have kits in stock for the 2020 137 the last time I called you where waiting on parts of something.
Thx
