Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Here is a simple method to produce your own drive belt changing tool at home in the garage with basic tools:
1) Use a 3-1/4" holesaw to cut a circle out of 1/4" flat stock, then drill and tap M6 x 1 bolt holes on the outer edges. Make sure all three holes are in a straight plane.
2) Drill the center hole out to accommodate the diameter of the secondary retaining bolt.
3) Once installed, use a 10mm wrench to turn a fully threaded bolt (50mm length minimum) against the helix and open the sheaves. Only one bolt is needed to open the sheaves. I drilled and tapped a hole on each side in an attempt to maintain balance.
The M6 bolt needs to be removed and stowed in the trunk during operation!
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
The creative abilities of TY members and their willingness to share with other members is what makes TY such a great resource of information.
Really nice job on your DIY belt changing tool Joe.
Looks like I'll be getting my set of hole saws out of hibernation.
Hillbilly engineering at it's finest
Redbeard
- Oct 14, 2011
- IN
Thank you, Don!The creative abilities of TY members and their willing to share with other members is what makes TY such a great resource of information.
Hillbilly engineering at it's finest![]()
The bolt will leave a small scar on the helix, but not bad. Using an old feeler gauge between the bolt and helix would work well and wouldn't take up much space in the trunk either.
Here are a few more pics of my high tech manufacturing process, utilizing a piece of flooring from a grain bin to mark the holes in a straight plane:
Carla 123
- Feb 27, 2017
- Manitoba
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Nice job
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
The bad news is, you'll never get to use your ingenuitive tool since you drive an Apex.
The good news is, you'll never get to use your ingenuitive tool since you drive an Apex.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Joe good work again
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Cool tool! Unfortunately wouldn't be able to use it on my sleds neither.
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
- www.yamaheater.com
- 2007 Attak - LOVE my sled!!!
Nice Joe!
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Needs an official name. A catchy name.
1. The Phalangee Saver
2. Red Beards Cold Hands Belt Remover
3. The Circle of Life
4. The Red Rotary Pinky saver
5. The Grain Bin Belt HiJacker
6. TorqueMcPusher
Any more?
6. TorqueMcPusher
Any more?
Redbeard
- Oct 14, 2011
- IN
Steve, you crack me up bud! lolNeeds an official name. A catchy name.
6. TorqueMcPusher
Any more?
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
I just bought the Richmotorsports tool. I think he allows for the washer spacing? I had to remove the large on and install a thinner one .. It works well but it's $45 ..and I need at least 2..ugh..
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
All you need is a 12mm wrench on a helix bolt. The longer the wrench the easier it is and it's about as simple as it gets.
Redbeard
- Oct 14, 2011
- IN
I had never seen the tool you mentioned above. It does look nice and is priced right.I just bought the Richmotorsports tool. I think he allows for the washer spacing? I had to remove the large on and install a thinner one .. It works well but it's $45 ..and I need at least 2..ugh..
Redbeard
- Oct 14, 2011
- IN
But I wouldn't have been able to use my grain floor piece as a drill guide??All you need is a 12mm wrench on a helix bolt. The longer the wrench the easier it is and it's about as simple as it gets.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Innovation is good............... to an extent. I work as an electrical engineer doing research at a University and one important principle that I teach students is to keep things simple.
