MtN_Rx1er
changing my prim spring from 0-s-0 to y-s-y, weights 8FA-17605-10-00 with both rivs 4.5 to lower my rpms, i dont have my manual/discs with me where i am and was wondering if anyone has the torque spec for these arrowed pieces, unless i just marker line them and then tighten them to the lines again, should be prettty dead on hoping. (2004 rx1 mountain)
grader
10 ft lbs. on cover bolts, dont know what the pivot bolts are, i just go by feel on those, its not much with a small 8mm wrench.
stomper
Yep, according to the service manual 10 ft lbs on the cover bolt and 4.3 ft lbs on the other.
MtN_Rx1er
thanx for the specs guys!,got my clutching switched, runs great! i ordered a manual/rep/maint disc for the machine so ill have all the specs now, i was givin one but it never ever did work
